Why isn't my battery charging?
I just replaced the logic board on my friend's macbook. It was randomly freezing whenever picked up. The replacement fixed that issue however the battery no longer charges when I have the computer plugged in. I am getting a green light on the magsafe charger. I've tried reseting the SMC as well as using a different charger. I installed coconutBattery as I've seen suggested and here is my reading:
current charge: 0 mAh
Load cycle: 14
Battery Status: Good
Battery Temp: 25.9 C
Charging with: 0.0 watts
Battery State: discharging.
Any help is appreciated.
2 Comments
Have you replaced the battery recently?
My battery in my MacBook Core 2 Duo 13.3in. had the same problem. My battery was bulging about to either explode or leak!
by Tim
When you ran Coconut Battery was the Mag-Safe adapter plugged into the machine? If so was it showing bright orange or green?
by mayer
