iPhone 5s does'nt turn on or Charge
I tried everything it won't turn on or charge
Hi Mehmet,
What did you try? When did your phone stop charging? Was it following a repair? A drop? Liquid damage? Is it new or used?
Anyhow, here's a quick troubleshoot:
If you tried new known new cables and chargers, then you need to clean the charging port using a soft tooth brush and 90%+ isopropyl alcohol.
Then you can try a new charging port. You can remove the screen, disconnect the old charging port, then attach a new charging port and test it. If it works, then you can follow this guide for directions on how to replace the charging dock. It also contains links for the needed parts and tools. Be very careful with the screws (step 11). Put them back exactly as they were.
Then you can try a
Next, try a new battery by following this guide.
If you already tried the above or more, let us know. Next step could be something wrong with your charging circuit on the logic board.
Guide
Difficulty:
Moderate
30 minutes - 1 hour
Guide
Difficulty:
Moderate
1 - 2 hours
Connect iPhone to Wall Charger and Reset until it responds. This means connect to Wall Charger and hold both home and power buttons until it responds, sometimes you have to keep holding both buttons for 20 seconds while connected to power.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 128
