Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
591 Questions View all
Can "sloppy" usb2 ports be replaced?
The two usb2 ports in the side of my MacBook Pro 15" have become "sloppy" and do not always read devices (flash drives and some other accessories). Its becoming more annoying!
A simple solution seems to be to replace the internals of the sockets... Can they be replaced? If so, how?
Thanks!
1 Comment
I solved the sloppy USB socket problem by running one line of cello tape around the outside of the metal part of the USB plug then I trimmed off the excess tape with a Stanley knife. The thickness of the cello tape takes up the excessive slop in the USB socket and the cord works just fine.
by
Add a comment
Chosen Solution
Sadly this is not an easy fix. The best solution is to visit an Apple Store and letting them replace the logic board for you (cheapest solution).
If that is not an option you could try replacing the logic board your self or if you have a friend that can deal with repairing logic boards he might be able to replace the sockets from a junker.
Score 1
1 Comment:
OK, thanks, Dan. So the sockets are kinda 'permanently' fixed to the logic board? They are not an easily replaced item. That helps me know which direction to head next. Cheers.
by
Add a comment
That's a real crappy answer!
Not that its not correct, but that its NOT what I wanted to hear, for sure!
I have the same issue, except that they DONT work far more often than they do! Mike, what did you end up doing?
1 Comment:
See for your self here: Logic board. The two connectors in the middle are the USB ports they are a custom part and are both thru-hole & surface soldered (very difficult to replace if you had a replacement socket)
by
Add a comment
You may be able to take a dental pick or equivalent and gently free up the spring strips on the outer shell of the UBS port. Specifically, put a little more flex into the retaining spring strips that are a part of the outer ground shield in the USB port instead of replacing them, if those have become flattened due to hard use. If the inner connector is broken or cracked, then it's logic board replacement time.
Add a comment
Add your answer
Mike will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 134
