The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 Questions View all
My phone wont connect to my charger.
I have a samsung galaxy s3 and it works but the battery dies fast and when i try to charge it the charger goes in but the phone wont connect to it. I have to move it around and hold until i find the right spot. Can anybody help??????
Score -1
1 Comment
Yea ive tried that with many chargers but ill try again thank you..
by
Add a comment
Chosen Solution
This is super common and a mainstay of any repair shop. Open up your phone and follow a guide to take out the logic board. The port is attached to the logic board.
Ports are pretty simple things---investigate it to see if you think it could be stuck back down with a soldering iron. If so, give it a shot.
If the port itself is damaged, then you'll need to replace it. This will depend on your skills. One of your local repair shops will be able to do it for you, or you can use a mail in service. If you have good soldering skills, it is something you can DIY--find a YouTube video and try it. Samsung s3 charge port is the beginner job of cell phone soldering.
However, If you are new to soldering, you will probably tear off a pad and that will complicate the soldering on of a new port---then you'll have to send it to a specialist like me to a complex charge port soldering job.
Best of luck, but either way this is definitely a solvable problem!
jessa
Score 1
1 Comment:
okay thank you so much
by
Add a comment
Most Helpful Answer
I usually do 2 - 3 charge port replacements on s3 phones every couple weeks. This is fairly common . the ports become loose over time and will require a little reflowing of the solder or may require a new port.
Score 1
Add a comment
Have you tried charging it with a different charger? It could just be that charger that isn't connecting correctly
Add a comment
Add your answer
kierra will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 867
