Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
no display after replacing screen
I replaced the screen (iFixit replacement screen) following the directions in the video, however when I power on the phone I get a few vertical white lines in the upper right corner? Did I do something wrong?
Score -1
Add a comment
Most Helpful Answer
Try putting the your old screen back on the iPhone if it works then you have a bad screen. If you are still having problems then you could have damaged the data filters or a small component on the logic board.
Score 1
1 Comment:
The old screen shattered
by
Add a comment
Make sure screen connectors are full pressed down
5 Comments:
It sounds like one of your 3 ribbons is not connected well.
by
I can't seem to get them to snap on tightly
by
Check to make sure none of the pins have bent. You should hear/feel it click in when you apply the pressure. Typically the first connection, the upper left is the problem connection when the symptoms you describe appear.
by
I finally got them to snap on tightly but after it's all put together, when I try to power on, the screen is black. Nothing.
by
Press and hold the Home button and Power button for 10-15 seconds, if it is a software issue it should be resolved. If that doesn't help the it sounds like a bad screen to me.
by
Add a comment
Add your answer
webgirllisa will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 73
