Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Question Closed
iPhone 5s won't turn on after Camera replacement.
I followed the iFixit camera replacement guide and after I finished it the phone wouldn't turn on. So I changed the camera back to the original. And it still wouldn't turn on. I double checked the steps. And still no luck. Can someone please help me?
Add a comment
Most Helpful Answer
Maybe you forgot to turn the device off. Disconnect the battery and power up again.
Score 1
1 Comment:
Thanks for your help. I tried what you said with still no luck. I read through the article again and it said if you put the wrong screw in the wrong hole it can cause severe damage to the logic board causing boot disfunction. That's most likely what I've done. After that I made sure the right screws were in there place. And disconnected and reconnected the battery. With trouble still.
by
Add a comment
Have you tried starting it up without the camera plugged in?
else if you have mixed up the screws on the shield which covers the lcd/digitiser/front camera, you could have damaged the traces
Add a comment
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 11
All Time: 499
