Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus.
4317 Questions View all
Can't get phone to boot after replacement battery
My old battery was starting to drain very fast and cause ghost touching issues from me dropping my phone a few times. So I got a replacement one (OEM) but after installing it I can't get my phone to boot. Just stays on the dead battery charging screen. Left it on overnight with wall plug and still no luck. When I put my old battery back in my phone boots and works completely fine where I left off so I know there isn't anything I messed up. I read up someone else had this issue and got it to turn on after being on charger for a full two days. Doubt I'll be able to leave it on that long so any suggestions on how to force it to boot?
Comments:
I replaced my battery on the iPhone 5 and had the same problem. Seems I got a bad battery as well but when I tried to take the bottom screws out, they will not come back out. Look as if they are turning in both directions but will not come out. Anyone have any suggestions on how to get the screws out so I can put the old battery back in?
by
Add a comment
Chosen Solution
Get a new battery. Defective "new OEM" batteries are a dime a dozen.
Score 1
Comments:
The only reason I can imagine you replacing the battery w/o taking phone to Apple is if you got it wet---did you?
by
Yep it was defective. They had to send me another battery, that one booted right up.
by
I've stopped supplying and fitting batteries to customers phones because of this issue, probably 75% of replacement "OEM" batteries are garbage and it's impossible to know which are good or bad before buying them.
by
Add a comment
Most Helpful Answer
Hi Marcus,
You could have a problem with the charging circuit of your iPhone, a defective battery, or a mistake during re-assembly during the first repair.
I would start with the following:
1- Follow this guide to remove the bracket that covers the screen connectors (step 10), and *IMPORTANT* examine the screws that are holding the bracket in place. Make sure the sizes were correctly placed last time. If one of the long screws (tagged as Orange or Yellow) was used in place of one of the shorter screws (tagged as Red), you could have damaged the phone during the previous repair. Let us know if you see this.
2- If the screws were correctly placed, breathe a sigh of relief and continue following the steps till 18 and 19. Remove the bracket holding the (battery connector) and the (charging-dock connector) to the board.
4- Unplug those 2 connectors, not just the battery connector like the guide says.
5- Use a magnifying glass to examine the 2 connectors on the board, and the small components around them to see if anything is partly broken off, completely missing, or broken or torn.
6- If all ok, gently re-seat the connectors and make sure they are properly seated.
7- Re-assemble your phone, *watch-out for the placement of the screws of step 10!! place them were indicated and don't over-tighten* then restart and test your phone.
8- If the issue persists, this time you need to rule-out the battery: the one you previously installed could be defective. Try replacing again from a different supplier, or by putting back the old one.
8- If using a different battery doesn't solve it, and you still can't get your phone to hold a charge once it completely discharged using any new or old battery, you could have a problem with the charging circuit of your iPhone, that arises more often if a cheap knock-off cable and charger are used.
Apple would exchange your iPhone in this case, but since you already tempered with it, I doubt they will accept to anymore!
Let us know if the above helped, and if yes, what step in particular.
Score 1
Add a comment
Why not just let Apple replace it for free?
can you install the old battery to see if the phone will boot?
Add a comment
Add your answer
Marcus will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 239
