Repair and disassembly guides and support for dish washing appliances.
150 Questions View all
Issues since replacement of sprayer nozzle on Kenmore Dishwasher?
I have a Sears Kenmore Ultrawash QuietGuard Portable Dishwasher. The portable dishwasher is causing a hammer effect in our water pipes + leakage in our new sprayer nozzle since we replaced the sprayer nozzle. Seems to be in the hot water/in line as well as had occasional problems with it not fully draining after the last cycle.
Comments:
Have considered multiple options of issues, but would appreciate a more direct option(s) to consider before spending too much time on multiple options. Thank you for any help.
by
Add a comment
1 Answer
Chosen Solution
If you never had hammering and then it suddenly starts, most likely your plumbing system's air chambers have become waterlogged. You can cure water hammer by turning off the water behind the waterlogged chamber, opening the offending faucet and permitting the faucet to drain thoroughly. Once all the water drains from the chamber, air will fill it again and restore the cushion. If the air chamber is located below the outlet, you may have to drain the main supply lines to allow the chamber to fill with air again.
The air chamber will not drain properly if it's clogged with scale or residue from chemicals or minerals in the water. The chamber always should be larger than the supply pipe to preclude such clogging. Since the chamber is simply a capped length of pipe, however, all you have to do to clear it is remove the cap and clean out the residue.
If this fails to work there are more remedies.
Score 1
Add a comment
Add your answer
tina6044 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 79
