Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Questions View all
LVDS Cable Replacement - tried to repair now stuck!
Have attempted a repair following the guide on this site that someone posted in answer to the exact same question; however I didn't read the complete guide before starting and I now realise that the guide is actually only half complete - so I am stuck with no idea what to do next.
My story is a bit of a train wreck; poor battery performance meant I tried to replace my existing battery but I had a stripped screw (the one right over the LVDS cable!) and despite trying every tool possible inclusing drilling it out, I ended up having to twist the bottom case off to get access to the battery.
However on putting it all back together the screen is totally black - I can use it with a display cable to my TV but the laptop screen is just not showing anythimg.
Due to the location of the LVDS cable and the screw I am 100% this is the problem; having ordreed a new one and compared the two it seems to be missing a 'tooth' so that's more reassuring.
However I followed the guide here: MacBook Pro 13" Unibody Early 2011 Display Replacement
Assuming at the end I could just pull the cable out but it looks like I have to remove the glass and the LCD but I cannot find instructions for my model.
There is a video on youtube but the guy is speaking german so I am not too confident in following that in case he is saying important stuff!
Any help much appreciated!
Add a comment
1 Answer
Chosen Solution
The procedure to remove the glass and access the cable should be very similar to this. As the display did not change that much from '10 to early '11
Study the guide and notes (not just look them over) and obtain all the recommended tools before you begin (every job is easier when you use the proper tool)
Keep track of all the screws so you know what goes back where.
If this answer is acceptable please remember to return and mark it accepted.
Score 1
Add a comment
Add your answer
JonnyGerbil will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 803
