I used wire connectors it isnt working.Someone can help?
I used the method but only i used wire connectors it isnt working how is this possible?
That's what happens when you create you own solution, some of them don't work.
More than likely you do not have good contact within the connector(s), or the connectors may be shorting out (without images it's only guess).
Go back over the connections of the connectors. 99% of reassembly problems trace back to connections (connectors) that were "thought" to be correct but upon reexamination turned out to be poor or incomplete.
If this answer is acceptable please remember to return and mark it.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 55
Post a couple of images with your question. That would allow us to see what you see.
by oldturkey03
