Fans full power - sensors not detected - shuts down after time
Hi Everyone,
I have a 24" iMac 8,1 when the fans started a week or two ago going at full speed all the time. I opened it up and could see that all sensors were connected properly.
I then installed fan control and sensors and notice that there was not a sensor listed for cpu temp! there also isn't one for gpu either!
If i leave it on and do something intensive it just turns itself off after 10 mins or so. the temperatures look good at that time...?
I then rebooted and ran the apple diagnostics and got:
4SNS/1/40000000 TMoP- 130.000
I've opened it up everything looks ok and even stripped it down (logic board/graphics card out) and still no joy. I even put a new gpu in and still have the same problem so sensor must be ok...
Any ideas?
3 Comments
Ok psu is good as i swapped that too...
anyway...
UPDATE
I've fixed it (and am probably the first one too based on hours of searching the web)
The problem?
You wouldn't believe it ... a bad CPU!
I had an old 2.4 from and 07 iMac surprised it worked but thought id test it and it booted lovely fans normal and all temperatures were back!
Ever heard of that?
I am going to order a new correct cpu - it did have a 2.8 but will the 3.06 drop straight in as it was also offered at that spec?
Cheers all!
by Dan Wilderspin
Wow! what a lark. I've never encountered that one.
by Dan
Aha! Someone else with a similar problem. I have a late 2008 unibody Macbook Pro. Fans at max all the time even with cpu load below 10%. Fan control apps no use. All I get is 0° and 0rpm. iStat nano shows only HD temp (no battery, CPU, or GPU) even though my battery works but does not show up as installed. I don't have access to the Apple hardware test and nowhere near an Apple store.
I'm confused - this problem was or was not solved with a new logic board? One post says using a new board did not help, but the "**update**" says it made it work.
by the1spo
