The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3315 Questions View all
Will replacing a logic board fix a charging problem?
My phone recently stopped charging, and it won't charge at all, it is completely dead. I replaced the charging port and that didn't work, and I've changed my chargers also. Does my iPhone 5s possibly have a disconnect with the logic board and charging port? And if I replace the logic board, will it fix my problem?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
I would try a charging port you no 100% works first before blaming the logicboard but Tom is right ..
But if it is the board that's the problem then yes it will fix the issue but if you use the home button from your phone and a different board then you will lose the Touch ID..
Score 1
Comments:
Is there a way to add it back? The Touch ID?
by
No unless you get the home button together from the logic board donor, or you know people inside Apple to do the pairing process again.
by
Add a comment
Most Helpful Answer
There is no point in replacing the logic board, the logic board is as expensive as the phone.
Score 1
Comments:
But it would potentially fix my problem?
by
It will cause more problems.
by
Add a comment
Add your answer
hayg will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 145
