13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Questions View all
Stuck tri-point trackpad screw
Step 10 in the Trackpad Replacement Guide says "Remove the six 1.4 mm Y0 Tri-point screws securing the trackpad to the upper case." Unfortunately, one of these tiny screws seems to be jammed in its hole in the trackpad, and the three-lobe cut in the top (where the Tri-point Y0 Screwdriver fits) is stripped out, so the screwdriver can't get enough purchase to turn the screw.
Anybody have any suggestions for how to get this screw out?
Score -1
Add a comment
1 Answer
Chosen Solution
Here's a lot of possibilities.
If this answer is acceptable please remember to return and mark it accepted.
1 Comment:
Thanks for the tips. Unfortunately, I don't have the tools, and anyway these screws are so tiny (1.4mm "long") I don't think any of these tactics would work. I'll see what I can do.
by
Add a comment
Add your answer
HandyMac will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 562
