The Mac mini family was first introduced in January of 2005.
no boot device found
Hi, guess I have played too much with the Mac Mini. Controller for sound broke bought and installed a new one but this did not fix. Simply no boot device can be found any more. Any ideas.
tks + brgds
Eberhard
Score 1
Add a comment
Chosen Solution
Check all cable connections
Check/swap ribbon cable, if no joy you damaged your logic board
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Score 1
Add a comment
Try starting up from your optical drive with the system installation disk by inserting the disk and restarting holding down the "C" key. On the second page of the installation disk go to the pull down menu, Utilities, Disk Utility and see if it sees the hard drive. If so run Repair. If not check your cables. If the cables are OK, replace the drive.
Score 1
Add a comment
Add your answer
Eberhard will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 2,201
