Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Cracked home button, Touch ID not working?
Hi there! I had a 5S that got ran over a couple times, destroyed the digitizer and lcd, and cracked the home button. Replaced with a new display assembly, moving the old home button over in the process. Phone boots up fine, digitizer and home button works great, but Touch ID does not function. Could it be because the sapphire is cracked? When I go to enroll a fingerprint, it immediately fails. If anyone has a functioning Touch ID with a cracked home button please let me know. Thanks!
Score 1
Add a comment
1 Answer
Most Helpful Answer
Immediate failure of Touch ID means the system cannot establish communication with the sensor. The chip under the button is not properly initialized or was already destroyed.
Bad initialization can be fixed by resetting the device, destroyed chip... There is literally no one can save you.
Score 2
2 Comments:
Thank you! Will try to reset device and reconnect cable a couple times, otherwise I guess the chip is toast.
by
Is the spring contact required for touch id to work?
by
Add a comment
Add your answer
Jared will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 1,362
