Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2949 Questions View all
iPhone 4S battery won't last even after new one installed?
I bought a used iPhone 4S this summer and everything looked in great shape except the battery drained quickly. I replaced the battery with one from iFixit and everything went smoothly, but it didn't improve battery life at all. I've followed every battery saving tip I can find, but nothing seems to help.
With bluetooth off and WiFi turned on and little to no use, it will last a maximum of 7 hours. If WiFi is turned off, it will make it 12 hours before needing charged.
I've reset/reinstalled iOS several times. I thought I would give iOS 8 a try and see if anything was better - long shot I know. Now the phone with WiFi/Bluetooth off won't make it more than 5 hours.
I don't know where to go from here - what part(s) would you recommend replacing? If it were WiFi, wouldn't the battery last much longer once it was turned off? Thanks for any suggestions!
Score 2
Add a comment
Chosen Solution
Thanks for the suggestion. I tried a different battery but it didn't help, and it wasn't particularly hot anywhere, but you sent me on the right path. I tried turning off the phone, but it wouldn't stay powered off unless it was plugged in. I remembered that when I first got the phone it had some odd audio issues that were related to the dock connector (I cleaned it good and it took care of that problem). However, I suspected that might be causing my power problems.
I replaced the dock connector and it solved my battery issue. It's been doing a great job of holding a charge now!
Score 1
Comments:
Great answer and excellent trouble shooting. Good job in getting it done.
by
Add a comment
Most Helpful Answer
get a new battery---all parts vendors have some rate of defects.
check for a short--can you feel a spot on the board that is too hot to touch?
does your phone consume battery even when turned off?
Score 3
Add a comment
Add your answer
dramaekers will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 129
