Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
Question Closed
iPhone will not power on unless power flex is unplugged
Hello!
I replaced the LCD/Digitizer on the iphone 4 cdma phone and unfortunately used a defective screen without knowing.. I think.. The screen turned on once and it was pyscadelic looking at best for about 2 seconds and shut off..
Now what happens is the phone will not power on unless the power/mic/prox sensor is unplugged. (with a replacement lcd/digi)
Just ordered a power flex cable.. Do you think it will fix my issue? Anything else I can try in the mean time?
Add a comment
1 Answer
There are three possibilities causing the problem:
1. The power button sucked in and kept pressing the contactor.
2. The power key contactor on the flex sucked in.
3. Improper position to place the flex, which causes the press.
So when you place the new power flex cable, you should pay attention to the position and the power button to avoiding kinds of pressing.
Good luck to you!
1 Comment:
I replaced the power button flex cable and it fixed it. Yay!
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 59
