Error before clean install of os x
I Have iMac 2011 mid.
Today i've added Solid State Drive to my imac. Now I have original 500gb and SSD 240gb on which i planned to do a clean instal of Os X Yosemite. same os x that i had prior to addind ssd. After completing all the physical installation properly, i restarted the sysem to check if the system recognizes my new SSD, before doing a clean installation. Everything worked well. Two hard drives showed up in my disk utility.
Now the problem begins.
By holding option key i get into boot menu to erase both hard drives before installing clean version of os x yosemite.
after erasing the drives im trying to install clean os x, but i get this error "An Error occurred while preparing the installation. Try running this application again."
I Tried changing date and time through terminal (since for some of you it solved the problem), also did a reset PRAM.
nothing works so far!!!!
iMac (21.5-inch Mid 2011)
