Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Question Closed
Power on problem, could it be logic board?
Hello. I hope someone can please point me in the right direction.
I have an iphone 5 that was dropped on the sidewalk. The screen didnt break but the phone is dead. There are no lights or activity on the phone at all. If I plug it in to a charger, the phone just heats up and gets incredibly hot. Burning hot. I've tried plugging it into a computer with the home button held down - nothing. I've tried replacing the screen - nothing.
Does anyone think this might be a logic board issue? If you have any other ideas I would really love to hear them.
Thank you so much!
Add a comment
1 Answer
Chosen Solution
It could be the logic board, but your description sounds like the power from the charger either isn't reaching the battery, or the battery can't accept the power. In both cases, the charge applied through the Lightning connector has to go somewhere, so it's dissipated as heat.
I would check to see that the drop didn't knock one or more connections loose. The connections that I think might result in these symptoms are:
  • the connection between the Lightning Connector module (also includes the headphone jack) and the logic board
  • the connection between the battery and the logic board
  • the connection between the power button/audio control cable and the logic board
iPhone 5 Lightning Connector and Headphone Jack Replacement
iPhone 5 Dock Connector and Headphone Jack
iPhone 5 Battery Replacement
iPhone 5 Replacement Battery
iPhone 5 Audio Control and Power Button Cable Replacement
Check these three connections, and replace any cables/modules that appear to be damaged. If a cable looks torn, or a connector or board is cracked, that's a strong candidate for replacement. Since you're inside the phone anyway, this is a good opportunity to swap out the original battery if you've been getting reduced charge life.
iPhone 5 Battery Image
Product
iPhone 5 Battery
$29.99
iPhone 5 Lightning Connector and Headphone Jack Image
Product
$19.99
iPhone 5 Audio Control and Power Button Cable Image
Product
Guide
How to replace your iPhone 5 battery
Difficulty:
Moderate
15 minutes - 1 hour
Guide
Difficulty:
Moderate
1 - 2 hours
Guide
Difficulty:
Difficult
45 minutes - 3 hours
Score 1
2 Comments:
Thank you so much!!! That is really really helpful information. Thank you.
by
As my Fijian friends say, 'na wari' (no worries). Please post back and let us know what results from your experiments.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 6
All Time: 81
