Repair guides for cell phones by manufacturer Nokia, including smartphones and a wide variety of the iconic "brick phones". This category is for phones not using an Android or Windows operating system.
508 Questions View all
Device dead. RTC Battery oxidated
Hi folks,
we are a small telco company from northern Italy. We have a Nokia 6630 with some specialized measurment sw loaded. The sw license is hardcoded to the devide, therefore I absolutley need to fix it ;)
The phone does not start anymore. So I opened it with my protech toolkit and found the RTC battery oxidated. I cleaned the green patina off the battery connector and took out the battery (code XH414H). I desperately need to find a replacement.
Do you know anypne selling these kind of spare parts? did you have any other cases like this?
Thank you!
Christian
Score 1
Add a comment
1 Answer
Chosen Solution
christiancanal, the XH414H is actually a lead free high voltage-resistant reflowable capacitor rated to 3.3V.
Nominal Voltage (V) 3.3V
Electrostatic Capacity (F) 0.07
Internal Resistance (Ω) 70
Weight 0.07 g
Diameter 4.8mm
Height 1.4 mm
Looks like this one is a match and you can also get them from Digikey.com. Of course that is for the US market, as for Northern Italy, I am not sure. Anytime you have that much corrosion, you will have to clean your board properly with isopropyl alcohol and a soft brush and you will have to repeat that a few times.
Add a comment
Add your answer
christiancanal will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 2
All Time: 246
