Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
434 Questions View all
Before I swap HD to 3TB Seagate, what should I do first?
Have an exsternal 2tb HD that i use for time machine. The hard drive has failed as I see has the death wheel for hours. Bought machine from a Mac store but NO start up disk 10 OS have added OS snow lepord and worked great. would rather look dumb and ask the questions, before things go wrong: 1st format new HD first. to what format? with what? snow lepord disc or exsternal HD? These PC are weird to work on.
Score -1
Add a comment
Most Helpful Answer
First put an operating system on the external drive so you can boot from it. If you added Snow Leopard you must have bought a retail disk. If so, it has Disk Utilities on it to format the new hard drive. Give the drive one partition (this sets it up as GUID format. Then erase using Mac OS extended (Journaled). If the new drive is a 6 GBs it may have to be jumpered down to 1.5 GB/s, or just check to see if it compatible with 1.5 GB/s before buying.
Score 2
Add a comment
ST3000DM001
Interface Options SATA 6Gb/s NCQ 6Gb/s NCQ SATA 6Gb/s NCQ SATA 6Gb/s
Performance
SATA Transfer Rates Supported (Gb/s) 6.0/3.0/1.5 6.0/3.0/1.5 6.0/3.0/1.5 6.0/3.0/1.5 6.0/3.0/1.5 6.0/3.0/1.5
Cache, Multisegmented (MB) 64 64 64 16 16 16
Spindle Speed (RPM) 7200 7200 7200 7200 7200 7200
1 Comment:
It was suggested to check my mother board first before I buy a hard drive? OK I will. thanks for quick response.
by
Add a comment
Add your answer
William Hogan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 3
All Time: 48
