Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Can't remove Logic board from the iPhone 5?
I removed all the screws and the iPhone's motherboard is stuck and won't budge, i even removed the sim card tray, still no luck, this is the third phone i've had and don't know how to remove this stiff logic board
Score 2
Add a comment
Chosen Solution
If the SIM tray is out, then you have missed a screw. It will come out easily once all the screws are out----make sure you're not forgetting the 2 screws at the top case securing the antenna
Score 1
6 Comments:
I got those two out already
by
Let us know which one you missed when you figure it out. Logic board slides out no problem if all screws are out.
by
I pried on the board trying to lift it and it snapped from area where a screw was already removed, I guess the board was old
by
"pried on the board" ouch. well give me a call when you need a pry damage fix.
by
Where the battery has the latch that connects to the board .. We'll that part of the board is ripped , just that a tiny piece is it fixable by buying a bare board
by
Show 1 more comment
Add a comment
There are two screws one either side of the simtray left and right..
Or post a pic that would be great and we can point it out
4 Comments:
Pryed on the board were you left a screw in you mean logic boards don't stick when all screws are out
by
It did stick, don't assume because I can clearly see the board didn't have a screw there, if you disagree then don't comment!
by
Don't disagree just find it very weird
by
Hello nick email Jessabethany@gmail.com and post her pics of the damage and she will hopefully be fit to help..
There is a screw under the interconnect cables hard til see but the cables need removed to get at that screw. It's in that position you described
by
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 601
