Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
427 Questions View all
Optical drive will not eject disc
I tried to burn a cd, but the optical drive did not recognize the disc, and did not eject it. Now it is impossible to remove the disc from the drive. I several times switched the system on and off. No result.
Please help.
Thanks.
Score 1
Add a comment
Most Helpful Answer
Restart and hold the mouse button down to eject a disk. There are a lot more remedies if you need them, just ask.
Score 3
1 Comment:
Thanks, but this doesn't work. The proposal of orhanmagia doesn't work either. Perhaps the optical drive is physically damaged
by
Add a comment
Mac or PC?
Update
On a Mac you have to open Terminal the Type DF the you will have a list of the drives in your mac then type : diskutil eject [the name of the CD, usually the last name on the list] and then it should be out, if you are using windows I do not know the solution...
Add a comment
Add your answer
pswai will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 155
