Repair and disassembly guides and support for dish washing appliances.
705 Questions View all
Dishwasher is draining slowly , and not completely draining
I have a kenmore dishwasher (about three years old) ! I first noticed water at the bottom of the tub when the cycle was over! I thought it might be a clogged drain line, air gap! I took every thing apart and cleaned out both! Still no luck, so I ordered a drain pump and replaced that ! And I am still getting water in the tub ! I noticed it is draining , but very slowly ! Any help would be appreciated
Score 1
Add a comment
Most Helpful Answer
Belt, Water Pump
Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller
The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit
If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve
The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly
If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Other Causes and Conditions
Clogged or Improperly Installed Garbage Disposer
If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose
If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve
If the dishwasher won't drain the check valve might be stuck closed. The check valve is a device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is located in or at the outlet of the pump that the drain hose attaches to. Sometimes the check valve is accessed from the inside of the unit depending on the model.
Check Ball
If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Those are the main things to check. You might find some additional ideas on the Dishwasher Not Draining page. Good luck!
Score 6
6 Comments:
I have checked all these items on this list. drain pipe clean, no check value issues, pump has continuity and runs, it just empties at a trickle in the disposal when it used to empty forcefully. Is it possible that a drain pump could run at a slow RPM if it is on its way out? Hate to buy a replacement with a solid answer to that question. -- Thanks!
by
Sounds like you still have an unfound blockage somewhere in the system, keep looking.
by
I recently replaced the selenoid and when I turn the dishwasher back up right the check ball released and found a flat washer at the bottom of the dishwasher??? Where did this washer come from ???
by
Thank you so much for posting this. Our dishwasher wasn't draining and we had just installed a new disposal. We didn't even know about the plug! Once we removed it, the water drained again. You are amazing!
by
I have also checked the "normal" causes. Still the washer does not always drain. However if I press the "cancel/Drain" button it does always drain so that proves the pump works and the hose and valve are not blocked.
by
Show 1 more comment
Add a comment
If your drain hose is connected to the disposal, be sure the port inside the disposal is cleared.
Score 2
1 Comment:
This was my issue (food and debris clogged up into the port on the side of the disposal that drains from my dishwasher). Easiest way to clear it was from the air gap port on top of the sink, taking direction from this super helpful video: https://www.youtube.com/watch?v=rmG2JXQL...
by
Add a comment
Add your answer
Brian fletcher will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 28
Past 30 Days: 156
All Time: 61,216
