Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 Questions View all
Tricks for getting short 3mm cover screws to go in completely?
I am a computer consultant and I have replaced memory on many unibody MacBook Pros. I am very familiar with the cover screws and always use the correct #00 Philips, etc. I just purchased a "new" Mid-2012 MacBook Pro, so it's been sitting on the shelf since they were discontinued last fall, at least.
Anyway, upon its arrival, I immediately opened it to put a larger hard drive in it. When I closed it, I had trouble getting three of the cover screws on the short sides of the computer to screw back in properly. I notice they had thread lock on them from the factory. I think it's blue Loctite. I am wondering if it would be smart for me to clean this off (Loctite specifies a pretty nasty solvent for this) and put fresh blue Loctite on, if I'll have a better shot at getting them to go in properly. The other thing that makes these screws tricky is it's not really clear what the angle of the hole is, as the surface of the cover is crowned/sloped right at the entrance. Is the hole vertical or is it perpendicular to the slope? One is not sure which direction to apply force with the screwdriver when starting the screw. It's easy to accidentally cross thread these for this reason, although I must say, I've been successful many times. This is the first time I've been this stumped. Plus, it's brand new computer, and I want it to be perfect. Any body have a trick for nailing these every time? Am I all wet in blaming the thread locker? Do hardware specialists freshen the thread lock with every disassembly-reassembly?
Score 1
1 Comment
I found this document with an illustration at support.apple.com that answers my question regarding the proper angle for each cover screw.
http://support.apple.com/kb/HT1270?viewl...
Certain of them are vertical or perpendicular to the plane of the computer, and several are canted at at what looks like about a 15 degree angle. This drawing will help me be more confident that I'm not cross threading the screw, at least.
by
Add a comment
1 Answer
Chosen Solution
I've never had to remove the lock tight from a screw. I do not use pressure when putting the screws in. I put them in like I was putting on a tire. First one screw in a corner, then the screw diagonally across from it. I do the four corners first and make sure the cover is positioned correctly.
Score 2
2 Comments:
Mayer,
With a combination of your suggestion of fixing the corners first, and the drawing I found (linked in my comment above) that made clear the angles of the screws in each different hole, I was able to get each screw to go all the way in this time when I installed my memory that arrived yesterday. Thanks!
by
Glad I could help solve this problem ;-)
by
Add a comment
Add your answer
GalvanicMacPro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 623
