Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Touch Screen Digitizer Partially, if not completely, unresponsive
I have had a couple screens now for the 5 / 5C / 5S that have both ended up having trouble with the touch screen. Some areas are responsive, others are not - two screens that have specifically not responded over the "Q" on the keyboard.
Other screens have trouble picking up on swiping, or touching one part of the screen will select another. I've even had screens that go HAYWIRE and start sending random signals, causing phantom texts/swipes/calls.
I've never had this trouble working with 4's, so I'm wondering if:
  • Any one else is consistently having this problem?
  • This is a typical issue with installing screens into the 5?
  • There is an installation "watchout" when pushing screens back in (i.e. where to push when reinstalling) that could possibly help prevent this?
Thanks for any/all help!
Score 5
1 Comment
so i have a 5s that the screen is unresponsive and i bought a new screen for it. I put it on and still nothing. I checked if the pins on the digitizer were bent of something but they we all normal so i dont know what to do because my screen is completely unresponsive.
by
Add a comment
Most Helpful Answer
My father is having the same problem with his phone....
The screen is falling off and I can see light coming out of the phone
Sometimes when we go out i notice that the digitizer fails and we have to turn it off and on again
Does anyone know how we can fix this or has a simular experience?
Score 1
Add a comment
Make sure you aren't screwing any screws that are to long into the back of the screen, because that can damage the screen.
Add a comment
I replaced the screen on my Iphone 5s and I have the same problem, my screen sometimes goes crazy.
I found a video with a similar problem.
http://youtu.be/VPGX_3ORgqQ
I'm looking for solution but can not find anywhere
Does anyone know a solution to this problem?
Add a comment
Are you buying your screens from the same vendor? If so, it is possible the vendor has received a "lot" of bad screens.
Are you touching the ribbon cables excessively with your fingers? Maybe the connectors are getting dirty. You could try cleaning the connectors prior to reattaching them.
Add a comment
its possible one of the cables coming from the screen iside clipped in securely
Add a comment
I have the same problem of phantom touches with Iphone 5. With another (original) screen i have the same result. I've done a lot of repairs and this is the first time i encountered this. I am desperate for a solution! The repair itself was without any problem. Nothing got damaged as far as i can see.
Add a comment
I have the same issue along with the screen getting cloudy; there is no particular order to this it sometimes appear and then goes away. Tried a restore to factory setting without success. the issue was still present when restoring from backup.
1 Comment:
I just bought an IPhone 5c and the screen goes crazy by itself. Goes so big that I am not able to see any of the icons. Or basically disconfigurate the screen for not reason. Help please
by
Add a comment
I'm having problems with my iphone 5c. It is working fine untill the pop up boxes appear (the one that pop up when you need to enter apple id and pass, or agree to things) then it is completely unresponsive on the whole screen so i cant accept or enter anything with keyboard. It's really frustrating. I've done iphone and other phone repairs for 5 years and i've never come across this specific problem.
Add a comment
Seems like nobody has an answer to the solution, but does anyone know the cause? I have had my 5s for just under a year and it has never done this before. It started only today but that's long enough to recognise the issue.
1 Comment:
i think the issue is dust/moisture i replaced my 5s screen myself and it worked fine for a longtime but it wasn't sealed of properly now i have the issue that my phone sometimes texts by itself if i touch the screen. so i think it is some kind of moisture/ dust problem with the digitizer or the cables of it
by
Add a comment
My iPhone 5s is having same problem and after writing to the Apple community I came up with the solution that my Phone "Digitizer" may be having problem and needs replacement.
Furthermore, my phone was behaving normally since iOS 10, but after upgrading it to the latest version now, I'm !#^&@@ off whenever I'm trying to type text on keyboard or sometimes now even if the phone is in standby mode.
I guess now its time to change the device, as it's in my hands since 2014.
Add a comment
Add your answer
Tim Sekiguchi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 10
All Time: 21,209
