Repair manuals for over two decades of Mac Laptops—iBook, PowerBook, MacBook, MacBook Pro, and MacBook Air.
30535 Questions View all
Question Closed
External Drive Unexpectedly Ejects while transferring files
I've got a mid 2012, 13-inch MBP. I replaced the optical drive with a 1Tb HGST Travelstar. I used an MCE Technologies Optibay kit. I wanted to carry an on board mirror of the boot drive.
The computer treats the new drive as a mounted, external drive. There are numerous reports of external drives being unexpectedly ejected during large file transfers. Does not happen for small moves, say under 4GB at a time.
This essentially eliminates the possibility of using the drive as a backup. Purportedly, this started to occur after the 10.8.5 Mountain Lion Supplemental update.
Any thoughts on a remedy?
Thanks,
J
Add a comment
1 Answer
Most Helpful Answer
You might try doing this while plugged into mains power, and - changing energy saver settings to NEVER sleep the computer, and, NEVER put the HD to sleep.
Failing that - come up with a new backup strategy (e.g use a pocket drive (or convert your optibay drive to a pocket drive) via USB).
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 824
