The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
How mod fan ps3 fat?
I fix the YLOD on my ps3 fat but, I feel the system hot about 15 minutes I think so, if mod the fan it is better, could you help me please thank you
Add a comment
1 Answer
Chosen Solution
Adding extra fans to the system is usually a waste of time, especially on PS3's where there is a huge system fan as well as no room for others. Depending on how old your system is, you may be able to reduce a lot of heat simply by changing your power supply. A touch inspection will reveal how hot yours is running. If you have the first generation fat that can play PS2 games (These PSUs were the hottest), you can replace it with one from a newer fat system that will run significantly cooler. This site gives a chart that shows power supply compatibility between systems, I would take a look at that first. If you have a newer system, make sure that you properly applied thermal paste after fixing the YLOD. You need just enough to completely cover the CPU/GPU dies and no more, it shouldn't ooze or build up around the base of the chip. If you have a newer fat PS3, you may want to consider replacing it's 15-bladed fan with a 19-bladed fan that came installed on early systems. Compatibility of fans is also listed in the site above. Good luck!
Score 2
Add a comment
Add your answer
jose mascorro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 32
All Time: 5,969
