2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Need help with capacitors, resistors, or caps on logic board
While replacing the thermal compound on the heat sinks , I knocked off 3 parts that are either resistors, caps, or capacitors. I need to know what they are and the values so I can re soldier them. I don't have another identical machine available so I can't measure the values off of another.
The Macbook is a Macbook Pro Retina Mid 2012. a1398 EMC 2512.
Thanks for the help!
Score -1
2 Comments
Not everyone has the dexterity to work on logic boards. You might want to take this to a pro.
by
Actually I'm doing the repair for a friend. As you can see I have to replace the heat sink as well.
by
Add a comment
1 Answer
Chosen Solution
Paul, all three of those components are capacitors.
Reference Designator C8509 is a 1UF 4V 20% capacitor in a 0201 package
Reference Designator C8503 is a 4.7UF 6.3V 20% capacitor in a 0402 package
Reference Designator C8500 is a 4.7UF 6.3V 20% capacitor in a 0402 package
For C8500 and C8503 these should work. For C8509 anyone of those will do. Hope this helps, good luck.
Score 2
1 Comment:
You sir, have made my day. Thank you. I'll let you know when I get it done.
by
Add a comment
Add your answer
Paul will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 459
