Question Closed
detached power cord from the logic board, how to reattach?
I accidentally detached the power cord from the logic board.
it pulled off the logic board instead of coming out of the socket it is in
Does anyone know how i can reattach it to the logic board without getting repaired at a shop?
Do i need to solder it to the logic board? it seems like that would be a bad idea
there are two small metal prongs on the bottom of the socket that seem to fit in to the holes on the logic board
any help would be much appreciated!
2 Comments:
Could you post a pict of the damage done ? It would be easier to answer your question.
by
just posted some pics if these will help get a better idea of the problem
by
Add a comment
1 Answer
If you mean that the socket came loose inside the case, it is not soldered to the logicboard but to the DC-in board instead. It might be possible to solder it back on, otherwise you'll need a new DC-in board. Much less pricey and easier to change than a logicboard.
1 Comment:
no its not the dc-in board i don't think
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 1,329
