First-generation Apple iPad with Wi-Fi, available with 16, 32, or 64 GB. Model Number A1219. Repairs are straightforward and do not require heat.
130 Questions View all
Question Closed
IPad USB not reconized
Hi,
I own an IPAD 1.
I can charge it on mains but not on PC.
Either, the IPAD is not reconized by the conputer ou ITunes.
I tried the recovery mode but it doesn't work.
I tried to STOP/START the Apple service ... no fix ...
Could you halp me ?
Best regards
1 Comment
New charging port received and replaced.
Everything works fine.
That was the issue ... many many thanks for your help !!!!!
by
Add a comment
Chosen Solution
The dock connector needs to be replaced. Despite looking fine, it has failed. This is very common on first gen iPads.
Jessa
Score 1
3 Comments:
Many thanks. Is it easy to remove safely the IPAD 1 screen without breaking it ? I tried on an IPAD 2 ... and the screen break ... Best regards
by
Outch, IPAD 1st dock connector is the most expenseive connector ever seen ...
by
Easy? No. Possible? Yes. Different than iPad 2, you're removing the screen+mid frame as an assembly. Expect to break the metal clips. If you start at bottom right edge and free the plastic tabs on that side all the way to top right corner, then break and free the metal clips along bottom, you should have enough room to pull out the left side and top without breaking more metal clips. Then transfer a couple clips to bottom for reinstall.
Yes, dock connector is about 25 bucks last time I bought one.
by
Add a comment
Most Helpful Answer
inspect the charging port if even one pin is missing or bent it can cause the device not to be recognised by a computer. If a pin is missing or ben you will need to get the charging port replaced
Score 1
1 Comment:
The charging port seems fine. I cleaned it with a toothbruch.
by
Add a comment
The screen on the ipad 1 is held in by brackets on the frame so the frame and LCD will come out with it be gentle and patient and you will be fine :)
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 171
