Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo processor
310 Questions View all
Question Closed
iMac 2013 does not want to power up
My iMac works fine recently. I left the iMac keep connected to the power outlet. However, after several surges in the power, I tried to turn on the iMac but it does nothing, no sound or anything. It totally dead and does nothing. I tried to check the power outlet and it works perfectly with all my other device. Tried to do all the resetting advices but it stayed the same.
Any suggestion that I might to consider before I send this computer to technician?
Thanks
Hipo
Add a comment
Chosen Solution
If your machine is a 2013, it is most likely covered under Apple Warranty. Take it to an Apple Authorized Service Provider or contact Apple. Also I'd get a high quality surge suppressor to prevent damage in the future. http://www.newegg.com/Surge-Suppressors/...
Better yet get a Battery Backup:
http://www.apcguard.com/?gclid=CPuwuuW2i...
Score 2
Add a comment
You need at a minim a new power supply - perhaps there's logic board damage too. You need to use the LED diagnostic lights built into the machine…
If this answer is acceptable please remember to return and mark it.
Score 1
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 203
