Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20031 Questions View all
My Keyport and mousebad is not working?
My Keyport and Mousepad is not working. This starts two days ago, today it was function but now it´s againe not working? I have to use a external keyport and a external mouse now.
I tried already to restart the my computer, but this does nothing to the problem...
and before I had several times the problem that my MacBookpro doesn´t react on the keport and mousepad, but when ever that was, I just did a restart and it was working...
Add a comment
Chosen Solution
Check the ribbon cable under the trackpad.
(between the battery and topcase). There's a "known issue" with the routing of the cable over the battery and through a guillotine like slot in the lower case. Using the keyboard hammers the ribbon cable in the slot and can losen, or short that cable.
Quick fixes are:
  1. Simply flattening the cable by turning over the MacBook and pressing on it.
  2. Placing a folded scrap of paper or note between the cable and the topcase.
  3. Replacement of the ribbon cable.
Good Luck,
N.
Score 1
4 Comments:
I know that trick, but in my experience it never worked long.
by
Thanks! my MacBook is working againe, I just turned it and pressed on it!
by
Max - please mark my answer as accepted. Thanks, N
by
LOL. This actually helped me too. I think what worked on my now about 9 year old MacBook (with no battery installed) was massaging the black plastic pad under the touch pad. So, thanks!
by
Add a comment
This line of MBPs unfortunately has a record of failing topcases. I think it's some issue with the cicuitboard under the trackpad, which manages keyboard, trackpad and TP button. I never found another way fixing this than replacing the entire topcase. The keyboard can likely be reused.
Bummer, Apple!
2 Comments:
Can I change the topcase buy myselfe? And where a get such a topcase?
by
Remove the battery and look in the compartment to give us the exact Book you have so we may direct you to the right part and installation instructions.
by
Add a comment
Add your answer
max will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 1,014
