Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Questions View all
Battery will not charge after replacement
My iPhone battery has been shutting off at like 20% all the time so I figured I needed a new battery.....followed directions exactly while replacing my iphone 5 battery. The battery will not charge at all. The charging icon comes on and it makes a sound when plugged in but the percent wont go up at all. Put the old battery back in my iphone and the same thing. I tried a different cable...cleaned out the charging port....still same thing. It recognizes that its plugged in though. any ideas?
1 Comment
Did you found a way to fix it? if yes, send info to my mail id, add.vignesh@gmail.com
by
Add a comment
Chosen Solution
Had a iPhone 5 that was fake charging yesterday and a new lighting port solved the issue
Replace this before you dive into the logicboard damage
Add a comment
Most Helpful Answer
I tried to find the best picture I could find. Look above (about a cm in height) where the charger connector is at, there should be a few small towers. yea i don't think anyone discloses that info. You might be able to get it fixed by making a connection with a jumper pen.
Imei check Run the imei in the back of your phone. Most people have no idea that Apple warranties their phone for a whole year.
Score 1
2 Comments:
You may have broken the Charger power tower (it's located right where the Battery connector is). I should know because it happened to me once. Check and see if it's still under warranty, if so get a replacement from Apple.
by
not under warranty any more. where is this "charger power tower" at? have a picture? this is BS considering i followed directions exactly. no warning/mention in instructions of the possibility of breaking the charging portion. the fact i was very precise in removing battery makes me think many people would have encountered the same issue I'm having.
by
Add a comment
Add your answer
cetherid will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 3
All Time: 2,264
