Apple's line of laptops for professional and power users. To date, the MacBook Pro line includes 13, 14, 15, 16, and 17-inch variants, with major revisions defined by Pre-unibody(Original), unibody, Retina display, Touch Bar, and SOC (system-on-a-chip) designs.
20006 Questions View all
Question Closed
Is MBPro 17" Unibody Mid 2010 Logic board compatible with early 2011?
Hi!
I have searched Google high and low for answers. Does anyone know if it is possible to replace the logic board in the MacBook Pro 17 inch (mid 2010) with a board coming from a early 2011 model (i7 processor at 2.2 GHz)?
Thank you!
Add a comment
It is not advisable to jump years when swapping logic boards. The newer board has completely different graphics… I would stay with the mid-'10 model if you want a faster processor.
If this answer is acceptable please remember to return and mark it.
2 Comments:
Hi Frank.
I'm stuck in the same situation.
Have you done it finally?
And machead3, why do you mean the graphics?
I read everything is the same but the thunderbolt, but think the connector is the same size, it isnt?
by
Condres don't know what/where you heard they're compatible here's the definitive comparison - For future reference you posted a Comment in the place where only Answers belong. Please use the add comment link to the appropriate Answer or update your O.Q..
by
Add a comment
As a matter of fact, a colleague of mine owns a Macbook Pro early 2011 17 inch. So I tried to compare the motherboard layout with mine as careful as possible. Two things I noticed are:
- at least one mounting point is different
- the battery connectors look different
Other mounting points seem to be located on the same spots in both machines. Connectors for the DVD drive, the Bluetooth module etc are the same. I still think its doable. But the question is: is it worth it?
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 188
