Repair guides for the MacBook.
3786 Questions View all
Question Closed
Why is my MacBook 13" battery not charging?
My battery will not charge in my MacBook (black) 13". My battery was tested and it works and charges in other identical MacBook 13" computers. TEKSERV in NYC diagnosed the problem and said they thought it was the DC In Board.
I recently received a DC iN replacement board from iFixit and installed into my MacBook 13"
Unfortunately, my battery is still not charging.
Could the DC IN replacemnt board that iFixit sent me, be defective?
What about the battery connector? could that be the problem?
What other advice might you have to remedy this problem?
Many thanks.
Neil
neil10514@aol.com
3 Comments
Any liquid spilled on this MacBook ?
by
Thanks Marcus. I'll check the battey connector and specifically the end that connects to the logic board tomorrow.
That said, what might I be looking for? What might be something that looks "odd"?
Also, given that I have already replaced the DC IN Board, what would you say the likelhood might be that the battery connector is the issue?
I really appreciate your help.
Thanks,
Neil
neil10514@aol.com
by
Remove the battery and give us the exact model you have and we can better direct you to the correct teardown tutorial.
by
Add a comment
Chosen Solution
I'd just replace the battery connector. It's often the problem, and it's a cheap part, so if it ends up not being the issue, you would not be out much. DC-ins are very rarely at fault in A1181 MacBooks, so I'd be curious how exactly the shop you went to came to the determination that that was the problem.
Score 3
Add a comment
hi neil,
yes - the battery connector could be the problem - but to be honest - in all cases i've had - the cause was a fluid damage at the connector
Score 2
9 Comments:
No liquid had been spilled on this MacBook.
I tried testing each prong of the battery connector and received variable voltage readings. Could this mean that the battery is not getting the proper power from th AC power adpater when plugged in?
Thanks for your feedback.
Neil
neil10514@aol.com
by
Marcus,
what next steps do you suggest I take to try to remedy this problem.
Thanks,
Neil
neil10514@aol.com
by
hi neil, i would open the MacBook and check the battery connector visually - i mean not the part that's directly plugged to the battery. i mean the side thats connected to the logicboard. unplug it an see if there is anything white/black or simply odd looking
by
Probably one or more of the battery charging board 20 pins don't make contact in the logic board socket. It often happens after a liquid spill in this area and it caused by corrosion or a by a short.
by
Lemerise,
Thanks for the reply. To the best of my knowledge, there was no liquid spill. I removed the battery connector and inspected it. I did not see anything unusual when I examined the battery connector though I'm not sure what "something unusual" would look like.
What next steps would you suggest?
Thanks,
Nei
neil10514@aol.com
by
Show 4 more comments
Add a comment
Hi, I'm from Italy, sorry for my english...
I've the same problem, the battery doesnt charge, but if I push the case at the left of the key "shift" or if I push the usb of the mouse (the same position, left of shift key), the battery charge. What I've to do?
Thanks!
1 Comment:
Sounds like your battery connector is not fully seated, and when you apply pressure, the contacts connect and it charges. You might want to open it up and re-seat it from the inside, and possibly clean it as well.
by
Add a comment
Ok, I try to do it, thanks :-)
Add a comment
I have the same problem,first I had a problem with the magsafe and I replace the charger but now the batery shows "not charging" and the light its green and if I unplugged the magsafe the computer shut down.
what can I do?
Add a comment
same here, i replaced the battery connector today but it keeps the same, maybe the place where it connects has part of the metal removed so it doesn't make good contact, please a little bit of help over here, I'm a IT (uncertificated) for computers using Windows, but this is the first time fixing apple computers, I only wanted to learn the way the operative system works, but it complicated, also, maybe I sound rude or misspelled, but this is not my first language, help please
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 14,993
