Repair information and guides for the fifth generation of iPhone. Model: A1387
I don't know what screw is iPhone 4s battery conecter's
hi i have an iphone 4s. While i am changing it's battery i lost battery conecter's two screws so i bought screw set i don't no what screw is battery conecter's screw
I hope you to give me some pictures and advises
Please help me
Score 1
Add a comment
The shortest screws!
1 Comment:
All the shortest screws are same size??
by
Add a comment
Sanghee, check this guide step 4 shows that " the following screws securing the battery connector to the logic board:
One 1.7 mm Phillips screw
One 1.5 mm Phillips screw."
Hope this helps, good luck.
Add a comment
Somebody should make a complete screw list. The ifixit ones are not precise enough, some screw s that have the same length have different diameter and heads, which mix things up during assembly
Add a comment
Add your answer
Sanghee will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 106
