Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Questions View all
Question Closed
Keyboard water damage, can I replace just the keyboard?
I'm looking to get some advice. My partner has a Mid 2012 Macbook Pro 13". She spilt some water on her keyboard.
The Macbook boots up fine, the backlight works fine. However some of the keyboard keys malfunction (mostly the bottom row). For example, when you press 'c' key it types 'cd' etc...
Does this mean that it is only the keyboard that is damaged? Can I buy a replacement keyboard and replace it myself? Or does the malfunctioning suggest it's another problem?
Any advice would be appreciated, thank you!
Add a comment
1 Answer
Chosen Solution
The logic board is fairly well protected from spills. *0% just require an uppercase replacement. YIt needs to be opened and the logic board inspected for any liquid damage. To test if the logic board is working OK, hook up an external keyboard and mouse and see if all works well.
Here's how to replace it: MacBook Pro 13" Unibody Mid 2012 Upper Case Replacement
Score 2
Add a comment
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 519
