Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
Hard Drive Replacement Suggestions
My Macbook Pro model A1278 2.3 GHz i5 mounts a 320Gb Hitachi hard drive as you know. During my last scan with Drive Genius, it showed I had more than 900 bad or suspect block at 1% of scan. The mac has been backed up fine with time machine and I haven't encounter yet in any corrupted files. However, I know it would only get worse. Should I replace my hard drive, and if yes, can I upgrade to a 7200 RPM or should I replace it with a 5400 RPM. I have two options for 5400 RPM. A 500Gb Hitachi Travelstar with a 7mm profile or 1TB Hitachi Travelstar with a 9mm profile. Would the 9mm fit? Which one would you recommend?
Hope I wasn't too painful!!!
Thank you for your time and best regards
MS
Score 1
Add a comment
Chosen Solution
I personally would go with a hybrid drive (HD/SSD combo) and you can use a drive that is 9.5mm high. Here's Seagates offerings Seagate SSHD and here's Western-Digitals offerings WD Blue series and Hitiachi Travelstar series
Your system can also support a larger drive than 500GB. The current largest drive that would work in your system is a Hitachi Travelstar 1.5TB
Both Seagate & Western Digital (Hitachi) make good drives.
Score 3
6 Comments:
The Seagate ST500LM000 is half the cost of the ST95005620AS. Do you know what the differences are?
by
Thank you very much for your help. My question though is: Can I upgrade to a 7200RPM HD or should I stick with a 5400RPM?
by
Either will work
by
Will a 7200rpm drive make any difference in speed in a mid 2010 unibody 2.4Ghz MacBook?
by
This post is a bit dated ;-} The largest HD available now is 2TB. As to RPM if all things are equal a faster RPM drive would gain you some improvement. But it comes with a cost! Uses more power creates more heat and tends to burnout sooner. I would again focus on hybrid drives like Seagate's SSHD or a dual drive like Western-Digital's Black2. Or if you can swing it go with a SSD drive. SSD's are still expensive when going with a 1 or 2TB drive ($400 ~1000 US). So think long and hard if that kind of investment is worth it for you.
by
Show 1 more comment
Add a comment
Most Helpful Answer
First determine if it is indeed your hard drive or the hard drive cable ( known issue and pet peeve of mine). These bad cables will also destroy a hard drive. So test your hard drive outside of this machine. Use another Mac or a Universal Adapter Universal Drive Adapter. My favorite hard drive replacement in this machine is a hybrid drive, the Seagate Momentus XT, such as this one: [linked product missing or disabled: IF107-098].
Turn your current hard drive into an external drive with this adapter. Image
Product
$34.99
Score 3
2 Comments:
marcosa, why the down vote? I might be right. You won't know till you try to replace the drive.
by
Sorry Mayer didn't mean to. I was trying to give you one up but doesn't let me do it. Even if I hit the upper arrow will go down 1!
by
Add a comment
These MacBook Pro models support a 2.5" notebook hard drive or SSD that is up to 9.5 mm tall (0.37 inches) & use a SATA interface. Your model supports 6.0 Gb/s aka SATA 3.0.
So how much you want to spend will determine what you buy...be aware that the industry nickname for "Travelstar" is "Deathstar" (due to a high rate of failure) perhaps a different manufacturer is worth considering.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
1 Comment:
by
Add a comment
Add your answer
marcosca84 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 20
All Time: 4,660
