Repairs for most tablet computers. Because of their small size and frequent use of adhesive, tablet repair is often more involved than laptop repair.
18922 Questions View all
Question Closed
How do I remove the rear case on a Zeepad FlytouchX Tablet?
This FlytouchX tablet is the 9.7 inch tablet as seen at this URL = http://www.zeepad.net/flytouch%20X.html
It has two problems:
1. Charge jack needs repaired.
2. The tablet USB connection is not recognized on any of three different notebook PCs. Since USB is faulty I can not update its USB driver.
Any help would be appreciated.
Jay Reynolds
reynoldsj8@outlook.com
1 Comment
Hi. Thanks but my Flytouch X has no screws. The back is wrapped around the internal boards and seems to be slotted into the glass front. There is no indents or visible spots where a tool can be inserted between the glass and the back. If I put it face up on a pad and press out on the long sides at the edge of the cover it seems to spring open at the mid point. However without being able to do the same at the corners of the case, I am afraid the back will distort. Any ideas?
Jay Reynolds
by
Add a comment
1 Answer
Chosen Solution
Here's a video on tearing it down: http://www.youtube.com/watch?v=53lF0XAFY...
Here's how to just take the back off: http://www.androidtablets.net/forum/gome...
Score 1
3 Comments:
Hi. Thanks but my Flytouch X has no screws. The back is wrapped around the internal boards and seems to be slotted into the glass front. There is no indents or visible spots where a tool can be inserted between the glass and the back. If I put it face up on a pad and press out on the long sides at the edge of the cover it seems to spring open at the mid point. However without being able to do the same at the corners of the case, I am afraid the back will distort. Any ideas? Jay Reynolds
Jay Reynolds, 18 seconds ago
by
Hi. Thanks but my Flytouch X has no screws. The back is wrapped around the internal boards and seems to be slotted into the glass front. There is no indents or visible spots where a tool can be inserted between the glass and the back. If I put it face up on a pad and press out on the long sides at the edge of the cover it seems to spring open at the mid point. However without being able to do the same at the corners of the case, I am afraid the back will distort. Any ideas? Jay Reynolds Jay Reynolds, 18 seconds ago
by
Sorry! An hour of searching netted me nothing on repairing, teardown or battery replacement.
by
Add a comment
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 526
