Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 Questions View all
Question Closed
After replacing power supply #1 led comes on then goes off?
Mac was dead, replaced power supply and #1 led comes on when power is applied, but goes off immediately. No voltages are measured on the power supply output, but 120VAC is present on the input to the board.
Add a comment
1 Answer
Chosen Solution
Contact your vendor - seem's like the power supply is still faulty. If you've experience and tools you could test it.
  • Should only be attempted by those with experience working with a multimeter or voltmeter and LIVE equipment.
  • If you don't know how to use a meter to measure voltages then you should not proceed.
If testing shows the power supply is not the problem, you most likely have logic board problems.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 6
All Time: 125
