1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
142 Questions View all
No Sound from Mac Mini!
I have a new problem that involves no sound coming out of the Mac Mini's speakers. When i received my Mini from the seller there was a gap to the rear of the unit as the party before me did not reassembly the top cover all the way. I gave it back to have the cover fitted correctly and now after powering on the unit I recognise that there is no sound, and plugged in some external speakers and got sound for just about 2mins then a lot of static. I then purchease a putty knife filed the edges and opened the case, but I found nothing that seemed like it was out of placeso I reassembeled.
Any suggestions?
Score 2
Add a comment
Chosen Solution
sounds like a problem with the audio board
maybe you should open the mini again and look if there is something odd with the board or the connection
Score 3
Add a comment
Most Helpful Answer
I had the same problem with a Core Solo machine. Turns out the people who installed some RAM (this was before I discovered ifixit) had not properly seated the ZIF cable in its socket.
Steps 7 and 8 in the Audio Board install (Mac mini Model A1176 Audio Board Replacement) are where the solution lies.
There is a painted line on the ZIF cable. Before you close the cable lock, make sure the cable is fully inserted - the painted line will be about 1mm above and parallel to the top of the socket. Push down the clip and all should be well.
Score 5
1 Comment:
this was it for me, SSD was installed by previous owner and the ZIF cable was re-seated BEHIND the actual connecter! Phew :)
by
Add a comment
I had the same problem with my MAC MINI A1176 Audio Board so instead of opening the case again I have scarified 1 USB socket and inserted a USB audio divice and it works just fine.
a internal can cost a 30 $ on eBAY but a USB dive can cost you 5 $.
Score 2
Add a comment
Thanks Gary, this was exactly it!
Score 1
Add a comment
Add your answer
Robert Antoine will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 24
All Time: 11,350
