Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Questions View all
How do I replace the frame where hinges and screen meet?
Basically the frame where the hinges attached to the screen just broke completely, just from stress I guess. It managed to stretch the rubber and crack the plexi glass on top of the LCD.
What piece do I need to fix it? The LCD screen replacement is the closest, but I'm not sure what parts I really need. Here are the pictures of the break...
http://imgur.com/Rp4qncu,27XwOaT
http://imgur.com/Rp4qncu,27XwOaT#1
I took out the screws but the pieces literally separate if not for the rubber holding them together.
Score -1
Add a comment
1 Answer
Chosen Solution
There's a guide for that. Looks like you'll have to locate the parts elsewhere. Purchase the proper tools (every job goes easier when you use the correct tools).
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
2 Comments:
Do you know what the actual name of the piece is though? It's not the full display since i have a perfectly good LCD, cam, airport etc. I'm just not sure what the frame is called or if there is a specific part number to research.
by
clutch cover
by
Add a comment
Add your answer
William will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 139
