The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
Storage Device Upgrade Options
Hi,
Is it possible to upgrade the storage on this 2013 Macbook Air to be like say a 512GB SSD drive? I believe I had found a guide on how to remove the SSD drive. However, could you please also post the various SSDs that we can buy to upgrade this device?
Score -1
Add a comment
1 Answer
Chosen Solution
At this time NO - apparently Apple has once again come up with a proprietary drive/storage system. There are no 3rd party solutions.
The MD711LL/A configuration has flash storage. Neither configuration has a hard drive. The higher-end MD712LL/A configuration also can be equipped with 512 GB of storage at the time of purchase .
*Apple does not intend for one to upgrade the storage after purchase, but it is theoretically possible. As first reported by AnandTech, this model uses a PCIe-based SSD rather than a SATA-connected one. Specifically, it uses a custom Apple design with a "PCIe 2.0 x2 interface, capable of a theoretical maximum of 1 GB/s in each direction."
So you'll have to be patient... OWC generally finds ways to upgrade these machines, but at this time they have not found an alternative.
If this Answer is helpful please remember to return and mark it Accepted.
Score 2
Add a comment
Add your answer
Anoop Kammaran will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,540
