help me plz back cover
My iphone 4s backcover wont come.off only one.screw comes off and cant take the other one off plz.help
Push, slide the back cover down into place all the way, towards the screws, much less than a mm but it will relieve pressure on the screw so you can remove it.
try using a different pentalobe screwdriver or place the screwdriver inside securely in the screw and bang in the screwdriver a bit so that the screwdriver can form with the screw where it can screw it out...... i have been in that situation many a time... god i hate when that happens.... usually it because the screwdriver cannot grip the screw due to the shape inside the screw being worn out... because you got one screw out you can try wiggling the back cover a bit to see if you can loosen the screw some... just some suggestons...
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 54
