Why is airport and soundcard not working?
Hello,
At first my airport hardware wasn´t working. (Hardware couldn´t be found.) After that my screen would remain black when turning the the MBP on, unless i pressed (apple+alt+r+p).The same problme occurs when in sleep mode for a long time. Now I have the same problem with my soundcard.
It seems that my MBP is slowly falling apart:-(
It is one of the first Generation but I would appreciate if you tell me how to save it? Or at least if it is worth repairing it?
Thank very much,
Kilian
Score -1
Add a comment
1 Answer
Chosen Solution
Hi, Before writing off your computer lets try a few things. First you should boot into your operating system disk but don't install. Select utilities/disk repair and run disk repair until it reports no trouble found. Then reset SMC and PRAM and see if you have improvement in the way your MBP works. Ralph
http://support.apple.com/kb/HT3964
http://support.apple.com/kb/HT1379
Add a comment
Add your answer
Kilian Teckemeier will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,603
