Mid 2010 Model A1278 / 2.4 or 2.66 GHz Core 2 Duo processor
795 Questions View all
Water Damage in MacBook Pro 13" 2.5Ghz
I have spilt tea on my "Water Damage in MacBook Pro 13" 2.5Ghz"
It no longer powers on. The HDD is fine and I'm pretty sure the RAM is ok. How much can I buy a replacement main board for?
Thanks
JP
Score -1
4 Comments
What are the last three digits of your serial number? this will allow us to identify your board. what have you tried so far to fix it? Have you removed the power from the board? Have you cleaned it with 90%+ isopropyl alcohol? How much corrosion does the board show? There may be ways to fix it, but you will need to provide more information.
by
Hi Thanks for your reply, my serial number ends with ATM. I have only removed ram and hdd. it powers on sometimes but I get no video display. I will try clean it with ISO. I will check for corrosion and come back to you.
by
2.4 GHz Core 2 Duo (P8600)
Intro Date: April 13, 2010 Disc Date: February 24, 2011
Order No: MC374LL/A Model No: A1278 (EMC 2351*)
Subfamily: Mid-2010 13" Model ID: MacBookPro7,1
Std RAM: 4 GB Std VRAM: 256 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
by
Also check all the connectors and clean those to make sure there is no corrosion on those.
by
Add a comment
1 Answer
Chosen Solution
Possible replacement boards.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
Jonny will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 978
