13" Unibody Mid 2010 Parts
In April 2010, Apple refreshed the 13" MacBook Pro line by increasing battery life to up to 10 hours, upgrading to NVIDIA Ge-Force 320M integrated graphics processors, and increasing the speed of the processors.
The Mid 2010 MacBook Pro 13" Unibody can be upgraded with up to 8 GB of PC3-8500 RAM. The 500 GB 7200 RPM SATA hard drive will give you plenty of storage.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
Results
750 GB 7200 RPM Seagate SATA Hard Drive Upgrade Kit (New)
SATA interface for Intel Macs / Seagate / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM.
See full description
$149.95
MacBook Pro 13" Unibody 2.66 GHz Logic Board
2.66 GHz Motherboard / Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot
$849.95
MacBook Pro 13" Unibody 2.4 GHz Logic Board
2.4 GHz Motherboard / Ports: FireWire 800, Mini DisplayPort, 1000BaseT Ethernet, 2 USB 2.0, Audio In/Audio Out, SD card slot
$649.95
MacBook Pro 13" Unibody (Mid 2009/Mid 2010) Display Assembly
Includes LED assembly, iSight camera, Bluetooth card, and AirPort card.
$499.95
MacBook Pro 13" Unibody (Mid 2009/Mid 2010) Upper Case
Case assembly includes backlit keyboard.
$299.95
120 GB Solid State Drive Upgrade Kit
Unformatted 2.5" 120 GB SATA SSD with everything you need to install the drive and transfer your files.
$209.95
750 GB 7200 RPM SATA Hard Drive
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 750 GB Unformatted / 7200 RPM
$209.95
MacBook Pro 13" Unibody 8x SATA SuperDrive (Used)
DVD-RW/CD-RW internal drive / 8x DVD read, 24x CD read, 8x DVD-R write, 4x DVD-RW write, 24x CD-R write, 10x CD-RW write
$199.95
750 GB Hybrid Seagate SATA Hard Drive (New)
SSD speeds from the Momentus XT Hybrid Drive.
$199.95
SATA interface for Intel Macs / 2.5" wide x 9.5mm tall / 120 GB Unformatted / SSD
$199.95
