Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
The camera does not turn on..
Ask for help I want you to know, once I open the casing and motherboard her imac to clean the dust, all my cabel off, after I finished cleaning the dust off my reinstall. then I turn it on and when I tried it did not live camera and its indicator lights do not light up ...
I turn off my computer and unloading his PC again because one of my plug cabel and plug the camera back but still does not turn on ..
until now can not use camera n ..?
Score -1
Add a comment
1 Answer
Chosen Solution
Recheck all your connectors. Most often a connector "looked or seemed" correct when it was not square, snapped in, or ribbon cable not fully inserted, correct side up, cam locked down.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
1 Comment:
Machead3 Thanks, I will try to check the connectors ..
when his turn imac why yes its blurry LCD display .. I continued to click "SLEEP" after "SLEEP, the LCD display is normal, the problem is the problem ...?
by
Add a comment
Add your answer
Made will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 4
All Time: 160
