2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
power pads getting current but no boot
Problem:
- MB a1342 is not starting, nothing happens when the power button is pushed
Symptoms:
- magsafe led goes from green to orange and stays orange
- battery is charging as:
- I'm measuring 3.39v on one of the powerpads, 0v on the other, both on battery and on magsafe power
- when i bridge the pads, nothing happens (with or without keyboard cable inserted into logic board)
- SMC reset using <shift-ctrl-option-power> seems to work as magsafe led changes briefly to green, then back to orange
Any ideas what to do next, before I attempt to bake the logic board (which I've done before with and without succes :-) ?
Score -1
Add a comment
1 Answer
Chosen Solution
Orange on the magsafe could indicate a ground problem. Bridging the power jumpers is not a universal fix... just a way to bypass faulty top case issues. If your CPU or other components are bad they'll still be bad.
Examining and replacing the DC-IN board is a relatively low cost painless starting point.
Sorry I couldn't be more helpful or encouraging.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
Frank De Laet will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 218
